Cam selection/conversion Help please - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2010, 11:14 AM
Hey out there. Summit is no help so I was wonder if someone can help
with my selection please. I like two cam #'s one is a solid and one is a
hydraulic. I would like to know what they convert to in a hydraulic roller??
Compcam #11-678-5 is a solid what is the hydraulic roller version with same specs?
also I like the Compcam #11-250-3 hydraulic flat tappet, what is the hydraulic roller version with the same specs?
Thank you in advance.
Old 04-16-2010, 03:12 PM
E.T. divided by $ spent= Speed
I don't think you can really compare a hyd roller cam against a flat tappet cam.Roller cams have much less friction and are able to use much more aggressive quicker lobes.So evan if you have a hyd roller cam and a flat tappet hyd cam both at say 218@050 the rates of there ramps will be way differant.
Your best bet is if you want a hyd roller cam call the Comp Cams or "You fav brand here" tech line and ask for a recomendation.
Cam tight on insertion 70bird Engine 12 12-27-2008 07:51 PM
good cam? boatanchors Engine 6 11-19-2008 08:31 PM
roller cam selection for my monte ss redbandit98 Engine 37 06-21-2008 10:39 AM
Cam button length/clearance..? mrdreex Engine 1 04-12-2008 10:17 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
