cam selection help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2010, 09:15 PM
cam selection help!
i have a 71 gto with a stock 400 3.23 gears, with 8:2:1 compression and i need help selecting a cam that will work best with my stock torque converter...your input will be much appreciated!
Old 08-04-2010, 10:47 PM
DoubleVision's Avatar
This cam is ideal for your purposes. However, if it still has stock valve springs, I would get the springs that match the cam. Install a new timing chain while your in there.
http://www.summitracing.com/parts/SUM-2800/
Old 08-05-2010, 12:18 AM
F-BIRD'88's Avatar
Yada Yada Yada
X2 good choice..
Howards Cams Greg T Engine 26 10-04-2009 12:28 PM
Would this Isky Hydraullic roller cam work good for my combo eric32 Engine 9 06-18-2009 04:36 PM
CAM Selection holding my build up (help) Carlos9 Engine 28 04-05-2009 12:40 AM
vortec cam selection, custom grind? slate84 Engine 13 02-04-2009 09:02 PM
Cam selection for pickup Chevy21 Engine 8 12-23-2008 09:00 AM
