Cam Selection help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2003, 10:46 AM
gpeak's Avatar
Cam Selection help?
Hi all! What is the better cam for performance on the street, Higher lift or more duration? Thanks in advance.
Old 11-24-2003, 11:48 PM
Mr.malibu's Avatar
All depends on what you want.Whats the run down on your motor and what do you want from it?It all takes play in what cam to pick.
Old 11-26-2003, 10:41 PM
billman's Avatar
It all depends on what kind of car you are running and how much you want out of it. As a general rule, higher lift can mean changing to a taller valve spring, which may mean machining the spring seats down a standard amount, usually .100 thosandths. If you want to avoid this, you can usually go up to maybe .475 lift without running into spring bind or crashing the valves on the pistons. You CAN monkey with the duration, opening rate, and lobe separation to see significant performance gains. I recently built a '64 El Camino with a 327. I have a set of pristine '65 1.94 Fuelie (Camel Hump) heads and wasn't about to machine the spring seats from the stock configuration. So I ran a Crower Compu-Pro cam and lifters, 286 dur. intake, 290 exhaust, .470 lift and 112 degree lobe. I wasn't too keen on 112 degrees below 300 duration, but the cam really makes a lot of power all across the RPM range and it pulls hard to over 5000. A great street cam, and it has a nice (although slightly subdued) lope at idle.
Good luck and good hunting.
Old 11-28-2003, 08:48 AM
Tazz
Call Summit
Speak with a Summit tech and tell them all the particulars and he will make a suggestion you will probably be able to live with and get a good deal on your cam.
1-330-630-0250
on line at: www.SummitRacing.com
contact Mr Gasket Co: www.mrgasket.com
also Scat Crankshafts: www.scatenterprises.com
www.procarbyscat.com
Todd
Rat Rods Rule
