cam selection for my poncho 400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2011, 09:42 PM
Last journal entry: ok starting after three years ..
72cc heads ported polished bowl blend,stock crank stock push rods and rockers edle intake and carb .... TCI turbo 400 and a 323 rear end ...
question which cam should i get ....
http://www.lunatipower.com/Product.aspx?id=2354&gid=297
or!!!!!!!!!!!!!!!
http://www.lunatipower.com/Product.aspx?id=2355&gid=297 !!!!
Old 12-26-2011, 10:46 AM
cam selection
http://pontiacstreetperformance.com/psp/camselect.html
268/276 cam is more aggressive of the two. Are you running a stall converter?
Old 12-26-2011, 11:37 AM
WDCreech's Avatar
Grumpy Old Goat Herder
Of the two cams that you show, I'd pick the first one. It's more apt to bleed of some cylinder pressure, but I don't think either will work with pump gas and 72cc heads!
Old 12-26-2011, 11:39 AM
Talking to Cliff Ruggles, a true Pontiac NUT and my experience as well, the first one will probably run better in your car. Pontiac heads seem to like the 112LSA better than the 110LSA.
If you have the compression, (you didn't say) the 110LSA will run pretty good, too but not have the broad torque curve I like on the street.
Be very careful of your ECR (effective compression ratio).
You can figure that here:
http://kb-silvolite.com/calc.php?action=comp2
Old 12-27-2011, 10:14 AM
thanks
yeah im running 17cc dish pistons should be about 9-1-1 comp...
Old 12-27-2011, 10:15 AM
just trying to get 400 hp ....
still 262 cam... no stall converter
Old 12-27-2011, 05:04 PM
MJS69's Avatar
I'm going to use the Lunati 262/268 in my 400 build...also TH400 in mine.
Which pistons did you choose for your motor?
Old 12-27-2011, 07:37 PM
KB icon 17 cc dish pistons ..
nswonfoswn
1967 Poncho Tire/Wheel Selection billme83 Suspension - Brakes - Steering 0 10-26-2011 11:18 AM
Why won't my poncho run? 67TEMPtress Engine 16 05-03-2011 04:02 PM
Hey Poncho, Waz This!! :( NXS Hotrodders' Lounge 2 02-04-2006 09:44 PM
Poncho! Doc! MI2600 Electrical 5 04-13-2005 07:06 AM
IFS for my poncho rwruther Suspension - Brakes - Steering 1 05-27-2004 03:37 PM
