cam selection for a vortec 350 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-06-2012, 07:36 PM
BigEd36's Avatar
Howards CL112431-06 cam/lifter kit would be an equivalent cam to the Isky 201268 recommended by F-Bird'88 with .450" lift, 223* @ .050" vs 224* @ .050" for the Isky cam. The Howards cam/lifter kit is $139.95 at Summit Racing, compared to $169.95 for the Isky cam with no lifters. Howards and Isky are the only 2 companies that grind all their cams in-house. There are Howards grinds that are equivalent to the other 2 Isky cams F-Bird'88 recommended, they don't come in cam/lifter kits, but they would save some money over the equivalent Isky grinds.
Ed
  #17 (permalink)
Old 07-09-2012, 11:15 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
X2,
and I'm willing to bet if you called Howards Cams that they would be willing to work a deal on selling you those other two cam profiles as a cam/lifter set for roughly the same price as their other kits.
Howards valvetrain products is all I ever use anymore, I've found them to be of great quality, price, and they also have great customer service. For as much as I recomend HRC products, I think I should get a discount on my next HRC purchase.
  #18 (permalink)
Old 07-09-2012, 04:29 PM
1971BB427's Avatar
I am a big fan of Isky Cams, but if you want to save some money you can go with one of the Crane cams sold under the Summit brand name. A cam/lifter kit will run around $120-$140 complete.
If you want lots of rumble and all sound you need a small (close) LSA number like 106-108 max. Long duration will help too, but I wouldn't go too long and have all low end power suffer.
SUM K00172 will give you a rough idle and not sufer ffrom low end power loss, it will also work with a stock converter, if the car is an automatic. 274/274 .450 lift and 106 LSA. $139. for cam and lifters.
edit-Oops! That Howard's cam is pretty much identical to the Crane/Summit cam set.
  #19 (permalink)
Old 07-10-2012, 05:40 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by my87Z View Post
you mention that this is a vortec 350 which automatically makes me think that this is a 96'-00' vortec 350 motor. if so these were factory roller lifter cam motors and the lifter bores are larger in diameter than the older flat tappet style motors. running a flat tappet lifter in these motors is not going to work, that lifter will slap all around and the cam nor lifters will last longer than the time it takes to break the cam in.
Really?? I and a couple people have ran flat tappets in these blocks and zero problems. Mine actually went in tighter than they should have and needed the lifter bores honed.
350, camshaft
350 Cam selection Madcam71 Engine 7 10-06-2009 02:33 AM
vortec cam selection, custom grind? slate84 Engine 12 02-04-2009 09:02 PM
350 Cam Selection? AR_Racing_627 Engine 13 01-23-2008 04:18 PM
Cam selection for Vortec Chevy 383 mytruckownsit Engine 7 06-14-2006 07:16 AM
350 cam selection help!? oregon chevelle Engine 3 03-13-2006 02:43 PM
