Cam Shaft Selection HELP!!!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2012, 01:06 PM
Hey guys. I have a small block chevy that Im building and have been pulling my hair out trying to decide on a cam so I though Id seek some opinions. Below is a list of things done to the motor. It is a street car that I will take to the track on the weekends. Any help would be much apreciated.
Fresh SBC bored .030 over
Stock cast flat top piston/cast crank/stock rods (10.5:1??)
Edelbrock Performer RPM Air Gap intake
Edelbrock Performer RPM Cylinder heads (64cc)
Holley 670 street avenger carb
Headers
Magnaflows
MSD 6AL box/MSD distributor
Old 05-29-2012, 01:31 PM
cool rockin daddy's Avatar
1.21 giga-watts???!!!!
Why don't you just buy the camshaft that Edelbrock has developed for the heads and intake? You have heard of their "Performer RPM" package, haven't you?
Old 05-29-2012, 02:27 PM
Yeah I have heard of the top end packages but havent heard great things about there cams.....well what I read online anyway.
Old 05-29-2012, 04:01 PM
F-BIRD'88's Avatar
Yada Yada Yada
What car? weight? trans? converter stall? gear ratio?
The Edelbrock Performer RPM camshaft is not bad but you can do a lot better
if you really want to go fast.
www.cranecams.com
have a look at their online catalog.
Then call their tech line.
or email them.
They will need to know and will probabily ask for the usual information you see on a typical Camshaft recomendation form.
They will get you all set up with the right stuff.
The Performer RPM camhaft is essentially a relabled
Crane (Wolverine) Blue Racer Cam
Its generic, it works (with the right gear and converter) , but they've got even better stuff.
Old 05-29-2012, 06:36 PM
spacytracy's Avatar
Last journal entry: New neon sign for the garage
I have the the Edelbrock RPM cam in mine with a nearly identicle set up. LOVE the cam! Everybody hears me coming, and when I drop the hammer its a sweet sweet ride>
Old 05-29-2012, 07:06 PM
Its a 72 celica. Weight is 2500 lbs. 4 speed manual trans. 411 gears.
Whats the idle sound like Spacytracy??
Old 05-29-2012, 08:14 PM
BigEd36's Avatar
Here's a YouTube video with a SBC idling with the Edelbrock Performer RPM cam:
Old 05-29-2012, 09:37 PM
Change of plans.......Untill I flip flop again :>) AFR has a dyno tested combo on there site. The bonus is they use a Comp Magum 270H cam and I have a brand new one that I wasnt going to use. Figure use the money I was going to spend on a cam and spend it on better heads...What do you guys think?? Combo makes 430HP @ 5500 and 470 ft lbs @ 4500
How accurate do you guys think those specs are??
Cam shaft selection bakerboys Engine 1 11-15-2011 07:39 PM
Cam Shaft Selection for Newbie (suggestions welcome) Silver Surfer Engine 1 04-20-2011 04:21 AM
Best cam selection 350sbrookie Engine 19 05-06-2008 01:40 AM
cam selection ajh86 Engine 9 12-14-2006 09:24 PM
CAM SELECTION HELP 383stroker Engine 10 05-15-2003 12:38 PM
