cam shaft specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2010, 06:19 AM
cam shaft specs
I,m rebuilding my Lt 1 350 chev currently i have a chev off road solid cam with the number 756 stamped on it, I,d like to find the spec,s on this cam so i can determine what cam to replace it with.
Regards Peter
Old 04-30-2010, 08:49 PM
sedan delivery's Avatar
camshaft
that may be a sealed power camshaft. try using the number and do some online research
Old 05-01-2010, 03:23 PM
F-BIRD'88's Avatar
Yada Yada Yada
You can determive the cam you have now by measuring the in and ex cam lobe lift.
GM used two factory cams and 2 off road service cams for the Z/28 LT-1 motors.
early 70 LT-1s had the duntov 30-30 cam "346" cam 254-254-.485-.485 114LSA
later 71 and 72 LT-1s had a upgraded cam with less intake duration and wider LSA for smoother idle/more low end w auto trans. 242-254 .459-.485 116lsa .024"-.028"
First design off road "140" cam 257-269 .494-.512 .024-.026 112lsa
second design is a biggy 262-273 .518-.536 112lsa.
Measure the lobe lift and x 1.5 for valve lift.
all the cam companies and GMPP sell new replacements for these original cams.
Would this Isky Hydraullic roller cam work good for my combo eric32 Engine 9 06-18-2009 04:36 PM
getting specs on a bbc cam 68sscamaro Engine 2 05-26-2009 10:58 AM
1998 Mercury mountaineer 5.0L roller cam specs eatonde Engine 2 01-10-2009 10:46 PM
Stock Cam Specs tc33 Engine 3 01-13-2005 09:02 PM
L88 cam specs Tiros Engine 1 11-03-2003 11:52 AM
