Which cam should I use - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2002, 06:15 PM
C10's Avatar
C10 C10 is offline
All throttle.. No bottle
Question Which cam should I use
I need a little help choosing a cam. I was recently given a 350 out of an 80's model vette and the motor is pretty much stock with about 50,000 miles on it. I'm not gonna rebuild it right now but I did lap the valves and change the valve seals since it was smoking on start up. I picked up a Holley Street Dominator intake and I'm gonna go with a Summit brand cam or a comp cam but I'm not sure which one will go best with this intake (I dont know much about cams). I know bigger is not always better but I wanna go as big as I can and still drive it everyday. My carb is an Edelbrock 650 and I'll also be using headers. The tranny is a TH350 and I'm gonna use the stock converter. If you need more info let me know. The motor will be going in my 86 Silverado (<---That one over there).
Thanks in advance,
C10
Old 07-25-2002, 07:05 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
Nice looking truck! I'd stick with a cam that holley recommends. If you don't want to go that route than a comp cam high energy cams work well on stock 1.25 springs and give a great lumpy sound. Call any cam company, tell them what you want,what you got, and they will give you you're best bet.stay under 280 Ad. and 480" lift.
Old 07-25-2002, 08:36 PM
E.T. divided by $ spent= Speed
Post
What gears and rear tire dia??
If you have highway gears I'd go w/ the summit K1102.If you have 3.42+ go K1103 or K1104.I think that motor is only 8.5:1 or 9:1 so I wouldn't get to nutz.All these cams should work w/ a stock converter.I've used all three and had good performance.
As far as brand I personaly would trust summit over com.As I've seen a few summits w/ good quality and have heard bad things about Comp.
Get a cam w/ usable RPMs.If you have highway gears you on't want a cam that revs 6500rpm you'll never see that on the street or strip.And vis vers i you got say 4.11s you won't want a cam that only revs to 4000 you'll wind out quick.
Old 07-31-2002, 01:55 PM
C10's Avatar
C10 C10 is offline
Post
Hey thanks for the replys. If anyone else has anything to add feel free because I still havent bought a cam.
C10 <img src="graemlins/pimp.gif" border="0" alt="[pimp]" />
