?on cam size. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2009, 07:39 PM
?on cam size.
does this sound like a custom grind cam?
lobe separation 103.3
checking height .050
valve over lap 30.1
intake duration 245.8 exhaust 254.6
intake area 28.49 inch deg. exhaust 30.57
lash .0100
intake peak cam lift .34135 exhaust .35315
intake peak valve lift .53615 exhaust .55503
intake lift @tdc .0848 exhaust .1161
centerline intake 99.34 atdc exhaust 107.34 btdc
intake open 10.49 btdc exhaust 54.95 bbdc
intake close 55.35 abdc exhaust 19.65 atdc
does any body no what rpm range this cam is made for?
its a bbc cam. rocker ratio 1.7 hydraulic flat tapp.
Old 03-16-2009, 05:20 PM
its already in my chevelle.the engine builder gave me a print out of the cam that was in my car when i had it gone over.he said he sent it out to get looked at and came up with these results.he is a well known engine builder in town.but it dont make sense to me either.having trouble with setting timing with this engine.its popping through carb at wot.it idles great takes off good but when im driving and stomp on it it wants to pop a little.????????about 4300rpms and up.
Old 03-16-2009, 05:47 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Intake valve sealing issues will behave like that sometimes. Certainly not the only thing that will, but one place to look.
How does it pump on a compression gage or better, a leak down tester.
Poor man's leak down:
Gut the hose from a compression tester by removing the Schrader valve, screw it into a cylinder that's @ TDC on firing stroke and pressurize the cylinder with your air compressor.
If bad enough, you can hear the air hissing at the carb (valves) or oil fill (rings).
Old 03-18-2009, 06:45 AM
thx, i am gonna double check my timing.i did find i had #4 wire boot arcing to my header so i changed it.gonna drive it today do some tweaking.thanks for all imfo.
cam size 78 chevy truck Engine 8 02-11-2008 09:57 PM
what size cam amiller08 Engine 2 12-06-2007 10:20 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 02:11 PM
305 cam carb manifold stickshift Engine 6 04-12-2005 04:46 PM
how to prepare a block blndweasel Engine 14 08-15-2003 01:28 PM
