cam size - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2003, 09:45 AM
cam size
ok i am going to build a 355 or a 383. whatis that best cam to use? it is not going to be a daily driver maybe 3 times a week just around town or down to the the canel. i ill be going to the stip alot next summer with all my buddys and there cars. my question is, i want to build this motor up good but i dont have alot of money. so i need to get a cam that sounds good with strait pipe and that is really going to do good on the track. this is going ito a 78 chevy 2wd truck with a 350 tranny and 373 gears out back. i was tinking on useing vortec heads.vortec intake,new HEI,headeres, roller rokeres,cast aluminum pistons and a 750 holly carb thanks for your help
Old 09-24-2003, 03:35 PM
help
Old 09-24-2003, 03:45 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
For what you are planning I would recommend a crate motor from GM, they have a 12/12 warranty with their motors.
You could not build one that cheap, you can get a 383 or a 385
http://www.gmgoodwrench.com/gmgoodwr...jsp?section=ep
Luv the smell of NITRO in the morning.
Old 09-24-2003, 05:58 PM
its all opinion man......
how much can you put up with is the question???
in my driver i had a 600+ lift in a sbc 850 holley, 261 castings ported etcetc, with dual 3" flowmasters.......yup it was loud.....but it was also very very fast.
when i build a motor for my nova its ganna be a sbc again...big carb, big heads, big cam, big exaust, then afterwards worry about how bad it is on gas milage.
Old 09-24-2003, 06:10 PM
i need to find the right cam i foun a stroker kit for 600 and vortec heads for 6. i have strait pipes on it right with glass packs that it so i f i put a differnt cam will i notice the oversize sound that i am looking for
Old 09-24-2003, 06:18 PM
WV hillbilly
Last journal entry: PTL 220CC
My cousin is running a 383 on the street in a 85 monte and he is using a comp cams magnum "280" and it sounds really good..he is also using a 3000 stall and 3.73 rear gears and it runs great..
Old 09-24-2003, 06:22 PM
i want it to sound like when you start you truck on a cold day a the choke is on that sound
is that 383 pretty fast
Old 09-24-2003, 06:29 PM
WV hillbilly
yes, its very fast...I think youd be very happy with the 280 magnum..he's running a holley dual plane, 680 street avenger carb, dart Iron eagles, comp 280 magnum and a stock one wheel peel 10 bolt...can you say traction problems? if he ever gets it hooked up it should run 7.90's to 8.0's in the 1/8 mile easy...he plans on mini tubbing it and going with a 9" whenever he gets the cash...HTH
Old 09-24-2003, 06:45 PM
i think my truck is 3500 ponds is that good or bad
or sound i build a big 350 small block with new heads
Old 09-24-2003, 06:46 PM
WV hillbilly
thats about what his monte weighs
honestly a basic 383 kit isnt that expensive, thats what Id do..
Old 09-24-2003, 07:03 PM
what heads and can you use stock
Old 09-25-2003, 02:27 PM
New Member
Um, the stock ones
Any 23 degree non-vortec head will work just fine with everthing else on your truck.
Old 09-25-2003, 04:14 PM
WV hillbilly
yes, you can use the stock heads..or if the cash i available there are many aftermarket heads that will work, dart, edelbrock, canfield, AFR, pro action, to just name a few...also the vortec heads will also work but youll have to buy a specific intake just for the vortec heads. I think you can buy them from GM for like 550$ a pair assembled, or scoggin dicky has packages available thats really hard to beat..HTH
here is scoggin dickey's web site if your interseted
http://www.sdpc2000.com/
Old 09-25-2003, 08:25 PM
E.T. divided by $ spent= Speed
Really you should wait till you have all your parts together befor yopu select a cam.
You need to know your:
cubic inch
intake
carb
compression
heads/valve size
headers(primarie size)
tranny type
converter rating
rear gear
rear tire diameter
weight of the car
also you expectations and needs and what your willing to put u with to get it.
Basically changing cams is tuning the torque curve of your motor,put the curve in the wrong spot or have parts that aren't capable of keeping up with the flo needs you may endup with a discouraging motor.
Nothing worse than over camming,especially if the car sounds bad but can't back it up.
Old 09-30-2003, 09:20 PM
bud-23's Avatar
Are we having fun yet?
Wink
like 78 monte said get your parts together and what i would do is call Isky. I'm a believer in Isky cams and their tech's. Just tell them what you have and what you are using it for and they will tell what works best. Bud.
