Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - which cam sounds good not piggish
Old 10-18-2004, 11:34 AM
rifraf's Avatar
rifraf rifraf is offline
I don't know what cubes you have,or what heads,but the older sb heads without rotators take the sum-k1103 no prob,and then some,in a 350 the 1103 sounds just a hair over stock but you can still hear it has a cam at an idle,and it works real nice with the stock converter,its right at that edge,and it still keeps good vacuum. That other one may sound stock,in fact,there are a lot of stock cams bigger than that. Just a heads up from a guy whos used em quite a few times. Maybe that other one is what your after?
