Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - which cam sounds good not piggish
Old 10-19-2004, 05:11 AM
club327's Avatar
club327 club327 is offline
Thanks fellas, good useful info there. The motor's in a 1971 HG Holden (GM) pick up that weighs probably the same, if not less than a 68 Camaro. It's appearance is not unlike your El Camino's, but again, probably the same dimensions as a 68 Camaro. It's rear end gearing is on the low side for such a torquey v8 to the point where I never give it full gas on take off. I'd say the gearing's around 3.55 or so. Yeah, the EPS manifold also means no adapter for my square bore Holley, which is a good thing seeing hood clearance is tight. Thanks. I love my 307 (bored out close to 327 cubes) and just about anything American, Fords included!
