Cam Specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2002, 12:56 PM
66chevy2ss's Avatar
Post Cam Specs
I contacted the previous owner of my car, and he said that the motor has a 510 lift hydraulic cam.
Anybody know how aggressive this is?
Old 09-12-2002, 01:22 PM
Post
I would consider this a very radical cam
Old 09-12-2002, 01:42 PM
66chevy2ss's Avatar
Post
thanks for the reply
This seems fitting, I hope, for a 350 from a '72 Nova (in my '66).
So I should expect some of the "issues" associated with "big" cams? (rough idle, power curve shifted upwards towards higher rpms)
Old 09-12-2002, 02:40 PM
woodz428's Avatar
Troll Hunter
Post
Depending on the era the cam was ground, it could still be fairly mild. Lift plays less of a role in the drivability than does duration, so you'd need more specifics about the cam. At one time a .510 lift cam was ground with fairly long duration( poor idle, low vacuum,etc.) but that isn't neccesarily the case.
