Cam Specs for a Crate Engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2007, 07:06 PM
Anyone know what cam would be in a 69 350/350 crate engine?
Thnaks
Old 10-20-2007, 08:36 PM
F-BIRD'88's Avatar
Yada Yada Yada
never heard of a "69 350/350 crate engine"
If you are looking for the cam timing specs for a 1969 L-46 350hp 350ci small block that came in the 1969 corvette they are
222-222@.050 .450"-.460" lift 114LSA when installed using a stock GM timing gear set it is 1deg retarded (115 deg intake C/L)
This same camshaft is used on the 1973-1974 9:1 cr L-82 350/245 net HP corvette and camaro Z28 motor. It is also installed in GM's 350/290hp crate motor. As you can see from the power rating this camshaft does not like a low 8.5:1 cr or crappy 76cc smog era cylinder heads.
There are better aftermarket hyd cams of similar duration and rpm range that will make more hp and torque. eg: crane #113801 HMV-278 Isky #201271/281-12 or Isky 201271
Old 10-20-2007, 08:56 PM
Thanks.
I guess I worded that wrong. It is an over the counter CE short block. I was told by the guy that installed it it was a 350/350 with 11:1 forged pistons. I pulled the pan and found 4 bolt mains, forged crank, windage tray HV oil pump. The guy put 186 otc heads on it as well.
Would you suggest the same cams for this set up in a 65 Corvette? Edelbrock RPM intake, BG 750VS carb, MSD ignition, Hooker headers to side pipes, Richmond 5spd, 3.08 rear.
Thanks again.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
Ford GT-40 Crate Engine Questions 31rdster Engine 8 11-27-2005 02:32 PM
What are the rough specs for a "3/4" race cam? willys36@aol.com Engine 20 05-16-2005 04:01 PM
Cam spec's ztoy Engine 17 03-08-2005 06:39 AM
