Cam specs please - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2010, 07:49 PM
Cam specs please
Hi im building a 4040 big inc SBC. the block is a worldproducts motown. A friend gave me two new cams Edelbrock #2201 & crower #00426 both cam are roller. My Question how far are the valves open at T.D.C. with the cam at split-overlap position. I talk to a summit tech he said call the company's. So i call & call & email & email no luck. This information will make it easy to check my v/p clearance. SOME HELP will shure be welcome....
Old 11-19-2010, 08:04 PM
68NovaSS's Avatar
Wiki Edits: 9
Edelbrock 2201 - Camshaft, Hydraulic Roller Tappet, Advertised Duration 296/300, Lift .539/.548
Crower - Adv duration 288/290 Lift: .570/.584
Also changed the title of your post.
Old 11-19-2010, 09:46 PM
cam spece pleace
oookkk..
Old 11-21-2010, 01:13 PM
I was looking to buy a Isky cam thay have all the overlap spece for there cams. so that you can know if the cam will work befor you buy it
Old 11-21-2010, 02:05 PM
68NovaSS's Avatar
Wiki Edits: 9
Every cam manufacturer should have that information readily available online
Old 11-21-2010, 09:09 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
There is no way to answer your question unless you know the amount of lift per degree of crank rotation as the intake is opening and the exhaust is closing, something only the manufacturer knows and does not tell the consumer. You might use the figure of 0.007" lift per degree, but that will only get you close, it will not be exact.
You should also know that piston to valve clearance is not a mathematical function, it is a mechanical function. Each and every motor must be checked with either the "clay on the piston crown" method or with a dial indicator and soft spring arrangement. There are simply too many variables to be able to sit down with pencil and paper and figure it out. For instance, not every valve seat will be the same distance from the block deck because of its position in the cylinder head, gasket thicknesses vary, piston deck heights vary, rocker arm ratios vary, etc., etc.
Vacuum reading with new cam sbc 350 eric32 Engine 17 09-05-2010 05:37 PM
Stock Cam Specs tc33 Engine 3 01-13-2005 09:02 PM
Cam Part Number specs Pgraphix Engine 2 05-26-2004 01:42 PM
L88 cam specs Tiros Engine 1 11-03-2003 11:52 AM
Speed Pro Cam specs?? Jare Engine 0 03-27-2003 09:01 PM
