Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam Sprocket button question?
Old 03-04-2013, 07:32 AM
Mr. P-Body Mr. P-Body is offline
If you're using the stock type cam and lifters (flat tappet, early engines are "solid" lifters, later are 'hydraulic"), everything will be fine. The "rake" on the lobe will "spin" the lifter and "push" the cam to the rear.
Jim
