-   -   Cam Sprocket button question? (http://www.hotrodders.com/forum/cam-sprocket-button-question-230308.html)
39chevy 03-04-2013 07:19 AM
I am bldg a mopar 225, slant 6, and my motor definitely didn't have a sprocket stop. Should I be worried about not having one, advise thanks, Dana
BOBCRMAN@aol.com 03-04-2013 07:31 AM
Flat tappet cams in general don't use or need a cam button.
Mr. P-Body 03-04-2013 07:32 AM
If you're using the stock type cam and lifters (flat tappet, early engines are "solid" lifters, later are 'hydraulic"), everything will be fine. The "rake" on the lobe will "spin" the lifter and "push" the cam to the rear.
Jim
39chevy 03-04-2013 08:00 AM
Thanks for all the info, I just learned something, AGAIN, Dana
