Cam and stall converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2006, 05:05 AM
JFM JFM is offline
This may sound like a stupid question but I am new to this and I would honestly like to know. What are the effects of running a stock torque converter when the cam manufacturer says that a particular cam needs a certain stall?
Old 10-17-2006, 06:33 AM
poncho62's Avatar
Wiki Edits: 5
Probably wouldn't have very good bottom end power.....If the cam manufacturer calls for a higher stall, it probably means that the cam is an upper RPM horsepower cam.
For the street, you want a lower torque cam.............generally.
Old 10-17-2006, 06:57 AM
Known traffic menace
Like Poncho said, If you run a big cam with a stock converter it's gonna be a dog out of the hole. On the street, you will want a converter with a little bit of stall at least to help with driveabillity issues,,at stoplights 1 foot on the brake, 1 on the gas to keep it from dying on ya, No fun. The main reason why they recommend a high stall converter is the converter is designed to slip to a certain rpm range before it fully locks up and will put the motor in the rpm range that the cam is made to work in and give you a better launch off the line. hope this helps, Perry.
Old 10-17-2006, 07:04 AM
Oh by the way, Welcome to the site. Alot of good info can be found here from alot of great people that like to help. Perry.
Old 10-17-2006, 09:17 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
There are two main problems. Your take-off power will be sluggish since the engine doesn't efficiently make torque at the stock stall speed. That alone is almost worth it on a just-for-show street engine, but the second problem is idle speed. With a high performance cam comes a much higher idle speed. You'll have to stand on the brake pedal with both feet to stop it, and every time you drop it in gear it will be a pretty good shock to the drivetrain.
Torque Converter Stall Speed leejoy Transmission - Rearend 2 09-17-2006 10:43 AM
B&M stall converter Lthompson Transmission - Rearend 6 11-29-2004 03:04 PM
stall converter adam15425 Engine 26 10-15-2004 05:50 PM
camshaft help novatech Engine 7 05-29-2003 09:42 AM
cam and stall converter questions dk01_99 Engine 10 01-03-2003 10:57 PM
