Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - which cam for a street/strip 383
Old 07-09-2011, 02:43 PM
my87Z's Avatar
my87Z my87Z is offline
Originally Posted by Landshark928
I agree with PRO 48 fleetline, The lunati voodoo solid rollers are sick. I have the 60133 in my 383 with Airwolf heads. With the voodoo cam and profiler 210, afr 210s or Airwolf 220 heads you would be closer to 575-600HP. I dropped the carb and have mine on Fuel Injection now. It has a very snappy throttle.
For street use I like the Voodoo cams due to the low recommended lash settings. Leads to a little more longevity.
based on acutall flow tests done on a 4.030 bore, my 200cc dart platinum heads (after some work) are putting out what the AFR 210 competition heads are in the .300-.600" range and acutally have better velocity numbers at the lower lifts than the AFR 210 Comp heads.
and i seriously doubt that i would be in the 575-600hp range, as neither of these heads is honestly that much better (if at all) than the ones that i have nor than a set of worked DART 215 pro 1 (new platinum series). i would likely have to change my compression to the 11-11.5:1 in order to see those numbers
having spent some time at the machine shop where i have my work done and seeing atleast a dozen or so motors run on a dyno, you learn that what you or others are going to make, very often is very different that what they actually do. i bet i have seen 4-5 383-406 motors come in where the builder or owner thought it should make 500-525hp and once it was run it really came out to be like 450-480hp.
