Cam stuff and your thoughts - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2005, 03:47 PM
Here's what I have. 83 pontiac g body wagon. Engine in the making, 350 Chevy. Parts on hand: 600 Holley, Performer intake, Lunati Bracketmaster 2 cam 00016 with specs--.458 lift intake and exhaust 218 @.050 intake and exhaust. LSA 110, 284 degrees duration intake/exhaust. 1 5/8 long tube headers. 350 transmission and am looking at 3.42/3.73 for gears. Not building a racecar but something for the family to ride around in. A/C will be here also.
I'm going to use this cam but can some one tell me if there is any "lope" to this thing? Also, it's ground with 4 degrees advance. What would retarding this cam 4 degrees do? I also thought about using 1.6 rockers on the exhaust but was told on another site that if I did to be sure and slot the push rod holes in the heads. I'm building it like the factory did, one piece at a time.
What are your thoughts on this combination?
Remember, If you bought it you own it. If you built it, it's yours.
Thanks for all your input. <><
Old 05-18-2005, 09:56 PM
Ratchet's Avatar
Last journal entry: Ontario Camaro Nationals 2008
Should have a very slight lope but will idle very well. I used a cam simialr to that with an automatic transmission and had no problem with idle at all.
Ric
Old 05-19-2005, 04:37 AM
cuda66273's Avatar
Rule number 1
Never ever retard a cam.
Old 05-19-2005, 05:18 AM
Last journal entry: PICTURE TEST
cam
Originally Posted by cuda66273
Rule number 1
That cam will have a very slite idle to it, Key word very. I have run cams with 235@.050 in daily drivers with no issues so you will be fine... Don't bother with the 1.6 rockers they will do nothing in your application....
Keith
Old 05-19-2005, 07:26 PM
Thanks for the comments. I'm interested in throttle response and torque. The transmission will be a 350C so I might even get some decent highway mileage. Still, I'd like it and my gray hair to surprise a kid or two at a stoplight! I just never seemed to get over that.
