Cam suggestion? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2010, 04:58 PM
Cam suggestion?
i am building a 383 sbc and looking for a good cam that will get me to 500hp of as close as possible. I've been very cost savvy and I got 1400 invested in parts that include,
1. 350 4bolt main std deck, align hone, bore and hone 30 over
2. balance Eagle 383 assembly
3. Dart iron eagle heads 64cc 2.08/160 215cc intake(former circle track heads) the springs are good for .570 lift
4. roller rockers and pushrods
__________________________________________________ _______________previously owned parts
5. Weind stealth aluminum intake
6. Holley 750 vacuum secondaries
7. Accel hi-energy performance distributor
I would like to make use of the parts I already had to keep cost low.
Now that is all out I have a four part question.
1. What would be a good cam for this set up.
2. will the head, stroker assembly work with the carb intake combo
3. What compression ratio am I looking at Ive done some calculations and
I came up with 10.427 to 1
4. what head gasket thickness can I use to bring the compression ratio to
10 to 1 or is it possible at all,
thanks in advance for any input
Old 12-19-2010, 05:20 PM
The mobile view is crap
10.5 is pretty high for iron heads. What is the deck height of your pistons? You don't want to put a .051 gasket to lower compression on a stock height block your quench will be like .080" when the idea number is .041" to reduce detonation. Give us some more information about the rotating assembly. Pistons and deck height.
Old 12-19-2010, 05:37 PM
I was afraid i was going to have some issues with the head/assembly combo
deck is 9.025 and the piston are speedpro flat -5cc hypereuctectic.
the heads(2) were only 500 bucks assembled and you can get a bare casting for around 450 new so it was a heck of a deal. i dont wan to buy the cheap procomps cause ive heard more bad than good
Old 12-19-2010, 06:04 PM
techinspector1's Avatar
Wiki Edits: 326
Your static compression ratio is over 11:1. You screwed up by using a flat-top piston with 64cc heads. Change the pistons or change the heads. Your choice. 18cc D-cups will put you at 9.7:1, a very reasonable ratio with iron heads and the proper cam to work with that SCR. (212 to 222 intake duration).
Old 12-19-2010, 06:27 PM
how did you come up with over 11 to 1, I looked in the book from eagle and is advertise as 10.7 with 64cc heads I might wrote down the wrong info..With that info is their any way I can bring the compression ration down to use 92-93 octane or are the iron heads the issue and if that is the case
ANYBODY LOOKING FOR A SET OF DART HEADS!!!!!!!!!!!!!!!!!!!!
Old 12-19-2010, 08:09 PM
Wiki Edits: 326
You and the book are figuring on having the piston down in the bore a little (piston deck height). I build 'em at zero deck to make sure the decks are the same distance from the centerline of the crank along the entire length of the decks, front to rear. Then, the gasket thickness becomes the squish dimension, usually a 0.040" gasket.
It takes 5 dimensions to figure static compression ratio.
1. cylinder volume
2. chamber volume
3. piston crown volume
4. piston deck height volume
5. gasket volume
Here's the way it plays out in your case with zero decks....
1. 784 cc's
2. 64 cc's
3. 5 cc's
4. 0 cc's
5. 9 cc's
Add these 5 values and find 862 cc's. Now, remove the cylinder from the mix and add the remaining values and find 78 cc's. Now, divide 862 by 78 and find 11.05:1 SCR.
With the same flat-top pistons that you now have and a set of 75 cc heads, zero deck and a 0.040" gasket, your SCR would be 9.8:1, just right for pump gas using a 212-222 intake duration cam. Also use a dual-plane, high-rise intake such as an Edelbrock RPM or Weiand Stealth and 1 3/4" long-tube headers with a 3/8" thick flange.
I'll list some heads for you to look at....There isn't much to pick through when you have to look at the larger size chambers, at least not with a decent sized intake runner. Truth be told, you'd be way better off financially to change the pistons and cut the decks while you have the whole thing apart again.
http://www.summitracing.com/parts/AFR-1050/
http://www.summitracing.com/parts/BRO-1028101/
Old 12-20-2010, 06:00 AM
1. cylinder volume
2. chamber volume
5. gasket volume
1. 784 cc's
2. 64 cc's
3. 5 cc's
4. 0 cc's
5. 9 cc's
thanks, Ill be taking the advice and go with the zero deck, and a different set of pistons, and assemble the engine. I never imagine rebuilding a centrifugal chiller was easier, but then again you are only replacing parts.
Old 12-20-2010, 06:48 AM
Landshark928's Avatar
FrankenPorsche
Rather than buying new pistons and then decking the block, wouldn't it be cheaper and easier to swap to aluminum heads. Don't aluminum heads allow for about an extra point of compression?
Procomp heads have gotten a lot of flack in the past but they are now on their third generation and redesign. They won't keep up with AFRs or Profilers, but for $469 bare from Skip White for the CNC models, they flow 270cfm @ .600" lift. Enough to make 500HP+ with the right cam. Most of the complaints you read about Procomp heads are either 3-4 years old, folks trashing on Chinese made products, or folks who just won't let go of Procomp's original issues. I am very happy with mine so far. I went to a dyno day this weekend and hit over 450RWHP with Procomp heads on my 383. Very happy. I'm just under 11:1 compression.
Old 12-20-2010, 07:15 AM
Banned
Those are some good heads, I would look into different pistons to lower your static compression, shoot for about 10:1-10.3:1, for a cam I am planning on running the Howards 180325-08 cam in an LT1 I am building with 1.6:1 rocker arms, 226/234 duration and near .570" lift with 1.6 rocker arms. If you get all of your engine specs together someone here can run a desktop dyno to give a rough simulation of the power curve it will provide in your engine. I have an old copy of desktop dyno 2003, but that thing is about as accurate as throwing darts.
Old 12-20-2010, 09:18 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
4. what head gasket thickness can I use to bring the compression ratio to 10 to 1 or is it possible at all,
Assuming 5cc reliefs, 0.025" in the hole, a 0.030" overbore, and 64cc heads, it'll take a 0.058" head gasket thickness w/a gasket bore of 4.100" to get 10.02:1 CR.
Problem w/that, is the quench goes to hell- at about 0.083".
Your plan to zero deck it and to use D-cup pistons w/the correct volume is the right way to go.
Old 12-20-2010, 04:41 PM
I have to go with cobalt on this one, keep the heads and swap the pistons, zero deck the block or deck it to 9.10 (to allow for an oops) and run a .035 gasket +/-. Are the pistons pressed on or floating? Are they brand new? Can you return them or exchange them?
Old 12-20-2010, 07:26 PM
I run into a set of pistons from speed pro part#L2403NF-30 for $200 the only info I got was that it had a 1.562 dish design and are forged pistons. Would that be equivalent to 25 cc, cause that would put me to 9.03 to 1 with std deck height(.025) and .015 head gasket to get total of .040 that is one of the cheapest routes, or I can go with speed pro 12ccfor $170 .025 deck and a .031 gasket and get 9.93 to 1 compression ration. Will this be the correct ratios and is 9 to 1 to low and 9.93 to 1 too high, any other piston with a range of 14 to 20 cc will cost me another $300. Any input on this two set of pistons will be appreciated.
Old 12-20-2010, 07:36 PM
Banned
9.93:1 is perfect, get it decked to true up the surfaces and run a good thin steel gasket.
Old 12-20-2010, 07:40 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That compression height and piston diameter is for a 3.48" stroke crank.
Old 12-20-2010, 09:00 PM
let me run this by u 12cc reliefs, .025" in the hole, .030 overbore, 64cc heads, with a .031 head gasket and a gasket bore of 4.100 will give me a 9.91 to 1 will that be a .056 quench? and is that acceptable.
Would this Isky Hydraullic roller cam work good for my combo eric32 Engine 9 06-18-2009 04:36 PM
Cam break-in and zinc Frisco Engine 34 03-13-2007 08:22 PM
Comp cam suggestion is whack??? BigTex88 Engine 9 02-20-2006 04:42 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
cam suggestion for DD with 1.74s COCHEV Engine 2 02-25-2003 11:22 PM
