cam suggestion - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2011, 10:01 PM
oregon chevelle's Avatar
cam suggestion
I am considering a new cam and would like thoughts. Motor is a 355sbc. It has headers and dual exhaust with h pipe, 300-36 holley dual plane intake, trick flow gen 1 aluminum heads with roller rocker arms and eddy 600cfm carb. This is in a 3500lb chevelle, 4 speed richmond transmission and 3.73 gears. Pistons are dished at -12.
Thanks for any help.
Old 02-04-2011, 12:54 AM
DoubleVision's Avatar
How do you want the engine to perform? Are you looking for it to lope? Street car? Strip car? Both? While the 600 carb will work, it`s a tad small.
I pretty much don`t do cam suggestions anymore as I lean to the conservative side. However, you know your compression ratio, your head flow and engine combo very well, then go to comps site, Isky`s site and find a cam that matches your combo. Most companies tell you what compression ratio and other mods they recommend plus gear ratios for the given cam.
Old 02-04-2011, 09:13 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
yup need more info on what you want the car to do
Old 02-07-2011, 08:15 PM
thnks guys. 9.5 on compression. Head flow is pretty good. gen one TFS heads flow really well on the exhaust side as well.
Suggestion of cam Spikejl31 Engine 15 01-29-2011 08:37 AM
need tie rod end suggestion.... user151 Suspension - Brakes - Steering 2 06-13-2009 05:24 AM
need suggestion chevy383 Engine 3 07-10-2007 12:44 PM
another cam suggestion 82c10 Engine 11 03-29-2006 08:18 PM
cam suggestion for DD with 1.74s COCHEV Engine 2 02-25-2003 11:22 PM
