Cam suggestion for 351M
I want to wake my 351M up and maybe even increase gas mileage a bit. I use my 77 Ford LTD as a daily driver. I like getting on it now and again, but don't have any big plans for it in the future, just a cruiser.
Edelbrock 600 and intake manifold, C6 transmission and 327 rear end. Stock manifold, but dual exhaust. I will also be swapping out the distributor for a 32720 performance distributor. My mode of thought is either a high energy comp cam 252H or 260H. Any thoughts, feedback or suggestions would be appreciated. I am a bit of a novice. Thanks, Steve |
Also, I plan on replacing the rods and lifters, with the swap, but many are suggesting replacing springs to avoid valve float.
One of the big thing's with the 351m is the 8.0:1 cr for stock engines. if you really wanted to wake it up you would need to do a complete re-build.
Punch it out a set of forged flat-tops trying to get it up to at-least 9.0:1 cr JMO You already have a decent fit with the edelbrock carb and intake. you will also need to throw some at-least 1 5/8 long tube headers on it also to help it out.JMO someone else will chime in with some more info and maybe better then what i have given you. there are some restrictions on these engines but you can still build a decent one out of them with some work and the proper set-up IMHO Cole
Thanks guys. I know the low compression ratio effects power and fuel economy. Could anybody who is familiar with my boat anchor spit ball what kind of increase I could see vs just re-camming? I found some aussie heads on line, but I am afraid of per-detonation with more than a 10:1 CR.
Thanks everyone |
pre detonation not per
Cole
| 351M, does it fit? | Luiz | General Rodding Tech | 11 | 08-12-2008 07:00 AM |
| 460 vs 351m | "70" Cougar | Engine | 11 | 02-17-2008 04:17 PM |
| 351m | cdiedrick | Engine | 3 | 04-29-2007 10:42 AM |
| 351m | delsman | Engine | 5 | 08-15-2005 12:15 PM |
| Need id help (351M) | fordmans | Engine | 2 | 08-08-2003 04:53 PM |
