Cam Suggestion, Please! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2007, 07:14 PM
Ok, I need a cam suggestion for my light street, mostly strip, drag car. My setup can take suggestions as well.
355 block
proffesional products 360* single plane intake
291 double humps: full port and polish, accepts .550" cam, 1.94 1.50 valves
hypereutic flattops
flowtech 1 5/8 primaries w/ 3 inch collector
4.10 gears w/ mini spool
boss hog 3000 stall
27.5 tall tires
#heads flow 245cfm at .500" lift
I want a rough idle and something hard to hold onto! I was thinking a .525 lift hydraulic flat tappet comp cams magnum?
Old 04-06-2007, 03:04 PM
TooSlow's Avatar
Beater Driver
Any idea what the compression ratio is on your engine? What is the weight of the car that this setup will go into? This will help get a better idea of a cam that will work for you.
Old 04-06-2007, 03:25 PM
When I want another camshaft ...
I call the camshaft manufacturer of my choice and ask them ...
They are professionals at this and they want you to be happy ... so you will be a repeat customer and tell all your buddies so they will be customers too ...
Old 04-07-2007, 09:05 AM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
I was thinking something right along those lines myself, that would probably make a good cam for him.
Old 04-07-2007, 05:04 PM
have any ideas on a hydraulic flat tappet? Im not much into replacing valve cover gaskets constantly.
Old 04-09-2007, 04:00 PM
hey thanks for all of the help guys! i will definately take your advice into consideration
350 build upgrade cam azbandit Engine 14 06-17-2006 06:00 PM
Comp cam suggestion is whack??? BigTex88 Engine 9 02-20-2006 04:42 PM
Please Critique Cam and Combo for 383 Chevy21 Engine 7 04-01-2005 12:50 AM
flattened cam 383vette Engine 7 05-04-2004 10:02 AM
cam suggestion for DD with 1.74s COCHEV Engine 2 02-25-2003 11:22 PM
