cam suggestions for 357sbc? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2010, 11:10 AM
looking for any cam suggestions for a 357sbc. looking for a solid roller. 11.1 comp. afr 195 heads. 3500lb nova, 4.10 gears. 3000 stall. th400. street/strip.
Old 09-01-2010, 01:58 PM
TroyBoy's Avatar
Psychomotors
Not trying to be a smart *ss but try calling some of the cam tech lines.Those guys are generally pretty helpful I have a 70 Nova,what do you have?
Old 09-01-2010, 03:30 PM
What are you looking to do with your 357 SBC?
This will dictate your RPM range,etc.
11:1 is alittle high for PG but with E-85 12.5:1+ is possible(some Mopar SB guys run 13.8:1 CR).
Old 09-01-2010, 03:34 PM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
http://www.summitracing.com/parts/LUN-60132/
http://www.summitracing.com/parts/CCA-12-771-8/
http://www.summitracing.com/parts/HRS-111203-10/
Old 09-01-2010, 03:39 PM
What year is the block?
Old 09-01-2010, 04:05 PM
techinspector1's Avatar
Wiki Edits: 326
Just to get you in the ballpark, you'll want 236 degrees duration @0.050" tappet lift. That'll match up with your static compression ratio and your converter.
Old 09-01-2010, 04:48 PM
I think I would use the 12-702-8 from Comp Cams.
Old 09-01-2010, 05:00 PM
Im Looking For A Street Strip Cam, Max Rpm Range 7000rpm. I Called Lunati And They Recomended Part # 60132.
Old 09-01-2010, 05:09 PM
Wiki Edits: 326
http://www.lunatipower.com/CamSpecCa...rtNumber=60132
Old 09-01-2010, 05:16 PM
Do You Think The Lunati Cam Is A Good One?
Old 09-01-2010, 05:20 PM
Troyboy I Aso Have A 70 Nova
Old 09-01-2010, 07:44 PM
Landshark928's Avatar
FrankenPorsche
I have the Lunati VooDoo 60133 with a 383 with slightly larger heads. Looks like you are on the right track. Look at the 60131, it would still be a beast but have better street manners.
What cam to get with my current build? havin_a_ball Engine 17 08-05-2010 12:46 PM
I've been told my cam is too small??????Any suggestions Eagle1 Engine 7 07-17-2010 11:06 AM
Camshaft Break In beertracker Engine 2 05-25-2010 07:13 PM
How can you be sure when a cam is failing? 4speed57 Engine 9 09-22-2009 03:12 AM
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
