Which cam for supercharged 440 on the street?
1973 Dodge Challenger. 440 with 6-71 supercharger. 440source aluminum heads. 1.5 aluminum roller rockers. 8.5:1 forged pistons. Stock forged crank. Either a 727 or A518 automatic; did not buy a TC yet, but thinking around 2400 stall and open to suggestions. 3.23:1 posi. I do not have tires / wheels yet. Will have P/B and A/C.
Car will be used on the street only so I need a reliable idle and enough vacuum for my brakes and A/C. I just need to to blow the doors off the imports that pull up next to me at stop lights.
I submitted this info to the COMP cams website and they suggested "part number 21-223-4 but I would ask for it to be custom ground on a 114 LSA to better accommodate the supercharger."
I then found a cam that seems similar but already has 114 LSA from Summit. The specs for both cams are pasted below. Would anyone recommend either of these or a different one? I have had decent luck with Summit cams in the past and am willing to use another one.
COMP CAM SPECS:
Brand
COMP CamsManufacturer's Part Number
21-223-4Part Type
CamshaftsProduct Line
COMP Cams Xtreme Energy CamshaftsSummit Racing Part Number
CCA-21-223-4UPC
36584046646
Cam Style
Hydraulic flat tappet
Basic Operating RPM Range 1,600-5,800
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 230
224 int./230 exh.
Advertised Intake Duration
268
Advertised Exhaust Duration
280
Advertised Duration
268 int./280 exh.
Intake Valve Lift with Factory Rocker Arm Ratio
0.477 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio
0.480 in.
0.477 int./0.480 exh.
Lobe Separation (degrees)
110
Camshaft Gear Attachment
1-bolt
Computer-Controlled Compatible No
Grind Number CRB XE268H-10
Valve Springs Required Yes
SUMMIT CAM SPECS:
Brand
Summit Racing
Manufacturer's Part Number SUM-6401Part Type
Summit Racing® CamshaftsSummit Racing Part Number
SUM-6401
Cam Style Hydraulic flat tappet
2,000-5,500
224
234
224 int./234 exh.
282
292
Advertised Duration
282 int./292 exh.
0.465 in.
0.488 in.
0.465 int./0.488 exh.
114
1-bolt
No
Yes
Camshaft Manufacturers Description
Fair idle, good midrange power camshaft. Requires 9.5:1 and higher compression, 2,000+ stall, and gearing. Good mild bracket racing cam.Quantity
THANKS SO MUCH FOR ANY HELP!
