Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam swap Questions
Old 10-18-2006, 04:52 AM
swvalcon's Avatar
swvalcon swvalcon is offline
Last journal entry: rust on lt body shell
All you have to do to the pan is remove the two front bolts. Then before you reinstall front cover cut the bottom of the cover at the seal at a angle so it slides back in.
