cam thrust plate? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2008, 08:56 PM
cam thrust plate?
got a 1991 sb350 just rebuilt. dont remember removing a cam thrust plate, so like a fool i just went back together without checking into it. i hear a noise that i am positive is timing gear to cover contact. question is, do all sb chevy have a thrust plate? please dont be too hard on me.
Old 07-06-2008, 09:15 PM
SSedan64's Avatar
If is has an OEM Roller cam it will have a thrust plate. Retro fit roller cams use a thrust button between the cam & cover.
Old 07-06-2008, 09:43 PM
not roller
the cam that came out was not roller. the one i put back was not. only change was i put an rv cam and a double roller chain.
Old 07-06-2008, 10:36 PM
SSedan64's Avatar
Some of the aftermarket double roller chains are wider and can rub the chain cover or the block area behind the cam gear too. If it's rubbing the timing chain cover try using 2 gaskets or a new aftermarket cover.
Old 07-06-2008, 10:52 PM
thanx. will try.
Old 07-07-2008, 02:22 AM
techinspector1's Avatar
Wiki Edits: 326
If the chain is rubbing on the block, remove the chain and cam sprocket, cover everything well so that no trash gets into anything and grind the face of the block to allow some clearance. No big deal.
will this cam work well? STLrocker Engine 9 03-29-2009 09:39 PM
New guy on pushrods and rockers Urbanfarmer Engine 9 08-21-2007 04:30 PM
Cam break-in and zinc Frisco Engine 34 03-13-2007 09:22 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 02:11 PM
cam lock plate Blob Engine 2 05-07-2004 12:30 PM
