Cam thrust washer - did I screw up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2012, 05:07 AM
Help! I took an Edelbrock gear drive off my hydraulic cam 350 Chevy and replaced it with a Melling double roller chainset. I forgot to remove the thrust washer that goes behind the cam sprocket against the block.
The chain and sprockets went on just fine and the cam bolts went in straight and bottomed out with finger tightness. When I tightened the cam bolts, the cam didn't walk. I used the cam button that was already there and the chain had some slack when I prelubed it.
What I didn't do was run a straight edge to check the gear alignment ......
The face of the thrust washer felt flush with the end of the cam.
Everything went together just fine and I ran the motor and it's very happy. Do I need to get the thrust washer out of there?
Thanks!
Old 09-17-2012, 05:16 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks!
It should have been removed- unless the face of the block was machined to offset the thickness of the thrust washer. If not, I'd feel a lot better w/it removed.
That said, there is some leeway. The gear teeth aren't as wide as the chain link is wide, so if the thickness of the thrust washer is not greater than the difference in the gear thickness compared to the width of the chain link, there won't be an immediate failure.
Old 09-17-2012, 07:08 AM
Thanks Cobalt327,
I'm calling Edelbrock tech this morning to see what they say but I'm planning on taking it out anyways. The face of the thrust washer felt flush with the end of the cam, but I'm not comfy leaving it in there.
Thanks!
i got the upgrade 4L60e sunshell, but no thrust washer.... old yukon Transmission - Rearend 5 04-11-2011 07:22 PM
American Racing Torq Thrust II center cap screw size? fasteddy51 Hotrodding Basics 5 09-29-2009 09:23 AM
cam thrust plate? tigercat73 Engine 5 07-07-2008 01:22 AM
SBC cam thrust washer?? sexypizzaman Engine 3 02-01-2008 04:29 PM
Thrust washer fell out. 454me Transmission - Rearend 1 05-21-2005 08:25 PM
