Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam tight to turn by hand?
Old 04-01-2004, 12:24 PM
BlackRat BlackRat is offline
New Member
Thanks. Just curious did you reply to my post at the Club Hot Rod forum suggesting scotch brite on the bearing? If not sorry. If so I did follow your suggestion and it did help although scares the heck out of me to be abrasive material on a bearing surface. As I stated in the post it is still a little tight but the bearing did mic to same spec as the others and does seem to be square in the hole. This might be a really dumb question but since it is turning smoother can this be tolerated and allowed to wear itself in or is it something that I am asking for trouble with?
