Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam tight to turn by hand?
Old 04-01-2004, 12:34 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is online now
Usually it causes no problems. I try not to use scotchbrite on bearings, I use a bearing knife. If I have a real super fussy customer I will use fine scotchbrite pad to "Hollywood" the bearing. Usually what happens is the bearing driver leaves a very small amount of bearing displaced at the very edge. A knife leaves the removed spot shiny while the rest of the bearing is dull.
