Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam timing
Thread: Cam timing
Old 06-19-2012, 07:47 AM
JohnTN JohnTN is offline
You got it right. At 6-12 the rotor should be pointing at #6, at 12-12 the rotor should be pointing at #1. You can put it back together either way.
If you put it back with cam/crank in 6-12 position and rotor at #6, when you rotate 180 degrees it will be at 12-12 and rotor at #1. And vice-a-versa.
If it is a new cam, you ought to degree it to confirm the valve timing.
John
