cam timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2010, 07:21 PM
topwrench's Avatar
Last journal entry: fish carb
cam timing
The subject of "straight up"timing a cam came up on another thread and I just wanted to know if anyone else in this forum has had experience with straight up or absolute cam timing.
Your comments on this subject,Im sure, will be appreciated by many and will certainly,Im also sure,be another learning experience to many others.
Old 09-04-2010, 05:53 AM
Duntov's Avatar
Visit the NASCAR Hall of Fame
Strait up?
I'm interested in hearing more on this.
Old 09-04-2010, 11:22 AM
topwrench's Avatar
Straight up timing
Involves timing the overlap on the xhaust stroke "straight up"
Absolute timing
On s.b. chevy lifter bores are all over the place,so if you think about it,the timing from cyl to cyl can be off by a few degrees,affecting the performance of the engine.
Lifter bores then need to bored out to adjust cam timing and bushed,actually a long time ago when we used flat tappet cams we could put a ford lifter in place of chevy lifter after boring on Bridgeport.
the ford lifter is just a little larger in dia.
Kicker is eng. is now dedicated to same cam.....
I see the phone rang and ur the only one that ansewered
Old 09-04-2010, 11:52 AM
Duntov's Avatar
Strait up
Straight up timing
Involves timing the overlap on the exhaust stroke "straight up"
Gonna take some for me to get a picture
Old 09-04-2010, 01:10 PM
Dirty Biker's Avatar
Bold As Love
I am just learning about cams, and I love the free trial of the engine dyno, engine analyzer pro3.9, I think I must surely have worn out my little virtual test engine doing so many dyno runs tho...
I made my virtual motor have a cam that opens the intake exactly at tdc and closes at bdc, and exhaust valve that opens at bottom dead center and closes at tdc to have a baseline to go from to see the effects of incremental changes one way or another. The thing that surprised me was how much power it still made with a cam setup like that. Also it made power right at idle... Really, 250 ft lbs from 1500 to 3200 rpm with 3 inch stroke 4 inch bore 6.25 rods. I just ran it again. Obviously I can get it higher with overlap and and duration but the point is what the heck man, that would be like a lawnmower cam or something.
Sorry topwrench if thats not what you are getting at by the term "straight up" but it made me think of my test motor and I been wanting to ask somebody about it. I can retard and advance that same cam overall to see the effects, retarding that same cam helps a bunch all over the rpm range.
Old 09-04-2010, 01:19 PM
techinspector1's Avatar
Wiki Edits: 326
When I run a DynoSim, I change the cam around with different advance and retard settings to find out if there is a better install than what is called for on the timing card, which is called "straight up" by many.
Old 09-04-2010, 01:49 PM
Bold As Love
You guys are very smart, and I would like an opinion on a crazy cam idea I have. If it is too crazy then I understand. ready? here goes: What if a cam is made that duplicates the intake and exhaust duration of a known good two stroke engine, like a cr500 honda motocross bike, only for a sbc, then 8 suitably sized expansion chambers are fitted to the engine.
Would these spanny chambers not have a similiar effect as on the two stroke engine?
That is to say, drawing the fuel/air mixture out of the cylinder while both valves are open then with the timed pulse of the expansion chamber pushing it back in at the last second before the exhaust port is closed, and because the intake valve closes earlier than the exhaust valve it could thereby increases the amount of fuel air mix in the cylinder than the piston actually could draw in.
Organic turbo boost.
I love two cycle motors sooo much because of this. The power comes on all at once at a certain rpm largely based on header pipe length but who cares.. It gets your adrenaline pumping and puts grey hairs in your beard and thats ok with me. Castor oil keeps you regular too.
I have been wanting to ask this question to somebody for about 15 years. I don't know any body who could even understand what I am talking about on this thing except maybe you guys.
A good expansion chamber design provides the equivelent of about 7 psi boost they say, it could be like a turbo with no moving parts if it worked... I realize two stroke engines are not the specialty of this forum but I wouldn't be surprised if you guys had already thought this very same thing before.
Im out there I know, sorry.
Old 09-04-2010, 02:10 PM
topwrench's Avatar
I knew somebody like Tek insp. would know it.
Phone got answered!
I dont know what you mean Drty B.??? whats the point?
@ tech inspector
I start my cam timing process at t.d.c. xhaust stroke and go from there
I think the most important event is the point at which"crossover" occurs,this is the point at which both valves are open the same amount,from the factory I find most cams when installed at factory specs this point occurs from 5 deg atdc to 5 deg btdc.
Please remember Im not drag racer,just round tracks.Well...... oval anyway!
Old 09-04-2010, 02:35 PM
Wiki Edits: 326
I'll have to think about this some before I give a response. In the meantime, I'll give you something to think about that I have considered doing but never got around to.
One of the problems with a 4-cycle motor is the balancing act between closing the intake valve either too early or too late to take max advantage of the incoming column of air/fuel mixture. Close it too early and you lose power from a reduced charge entering the cylinder. Close it too late and you lose power because the ascending piston pushes some of it back up the intake tract and out the carb throat.
What if a guy cobbled up an intake manifold that used 2-cycle reed valves at the head ports? I mean, leave everything as is except just add the reed valves between the carb and head port. Seems to me that this would optimize the whole mess. What do you guys think?
Thinking about it further, you would want some pretty agressive intake timing on the cam so as not to limit the effectiveness of the reeds.
Old 09-04-2010, 03:01 PM
topwrench's Avatar
im with u .....cell just gave up the ghost talkin to phone co,,
u brg up gud point n i wanna answr but tlkn with fone co.
Old 09-04-2010, 03:24 PM
Bold As Love
So to make the cam straight up then, like if I want to put a stock factory 262 cam in my 283 motor (which is what I think I am going to do becasuse it gives more power than the stock 283 cam on almost every range with stock two barrel manifold, the single hump heads, and 1.5 inch i.d. 32" length headers which is what I have to work with here) I want to degree the cam in so that the overlap of the intake and exhaust valves, that they are open the same amount I mean, at tdc? If so that is good to know. If not then I misunderstand.
Forgive me for my last post, but I am very confident that I could make expansion chambers that would work with a four stroke engine with the right camhaft timing. I realize that you may be unfamiliar with two smokers, but I am very sure that you can grasp the concept of the expansion chamber. The point is increasing the volumetric efficiency of a naturally aspirated engine far far above the swept volume during a narrow rpm range and with the least amount of moving parts possible. Just like forced induction, but with no parasitic drag or bearings to replace or lag etc. Again I appologize and realize this may be the wrong thread, or even wrong forum, to propose such ideas. I believe it would work, tho you would maybe need a cvt transmission of some kind to get the power to the ground and keep the engine at the right rpm.
FWIW, Although two stroke engines have no camshaft, they still have intake and exhaust events just like a four stroke, the overlap where the intake and exhaust are both open (and connected to each other via the combustion chamber) is used with the expansion chamber to create more power. During the opening of the exhaust port, the pulse of hot expanding gasses travelling into the megaphone exhaust chamber creates a vacuum which (scavenges?) draws out exhaust gasses but also fresh fuel air mix because of that overlap. Then the intake event ends and the intake port closes. The exhaust event still continues tho. There is a sharper angled reverse megaphone where the end of the megaphone would be that reflects that energy back into the engine, forcing that fuel air mix that it drew out previously back into the exhaust port before it closes. When it works, it works really really well. Scares you half to death going from 22 horse power at say 2500 rpm on a 250 cc bike motocross bike to like 57 horse power in the blink of an eye at 3000 rpm, only 500 rpms later, when the set of events lines up perfect. That is the best I can explain it on short notice. Plenty of good reading on it tho out there, the expansion chamber was invented around 1961 by a german dirty rotten stinking biker dude.
http://www.absoluteastronomy.com/top...ansion_chamber
Expansion chambers were first designed by East German Walter KaadenWalter during the cold war. They first appeared in the west on Japanese motorcycles after an East German motorcycle race in the 1961 Swedish Grand Prix. He hid the blueprints under his racing leathers and defected during the race by riding off the track and claiming asylum. He did not finish the race. He later provided the blueprints to Japan's Suzuki....
Thanks Topwrench
Old 09-04-2010, 03:40 PM
Bold As Love
Now that is what I am talking about!!! Yes that would be easy to do!! The reed valve cages I work with on the motocross bikes flow alot, and by alot, I mean the carb on my husky 430 is 38mm. It is actually small, the carb on a modern ktm 250 is about the same size but my bike is older and is designed for more tourque at a lower rpm. I still pray before riding it, and yes sir my dog still rides in the back. That equals 1.5 inches for us americans. We could put one on each intake port and run as much intake duration as you need for the power you are after yet still have good low end tourque, thats the whole point on the two strokers and it works just fine! Tech Inspector, you just made my day.
Old 09-07-2010, 11:43 AM
topwrench's Avatar
When an engine is running there is chaos inside the intake due to.
Intake dilution from exhaust,intake draw through to xhaust,flow reversal in intake,dry manifold as driver lets off throttle to go into corners,wet flow in manifold(small rivers of fuel).
I know how both cranckase charged and rootes scavanged 2 stroke work.
I just dont know how you would hold reeds inside a manifold so that they wouldnt create all kinds of other problems like interfering with the flow etc.
I think just about the only way to get rid of some of the chaos is to have forced induction and then has to be more than 10 psi or so.
Just got back home today.
Old 09-07-2010, 07:57 PM
LATECH's Avatar
Look at many of the new cars. A lot of them are using variable cam timing They can vary the timing for different operational conditions. A lot of it is to help make horsepower as well as help with keeping down emmisions.Older cars like my wifes camry had a centrifical advance on the cam drive pulley.You can feel it pulling at about 3500 rpm and up. (passing gear LOL)
Old 09-08-2010, 10:54 AM
topwrench's Avatar
I really think cam of the future is no cam
Either solenoid actuated or pnematic ,a La formula 1.
I believe we will all see that n also very high comp ratios just as soon as they figure out how to alloy ceramics into metals,50:1 on gas engines probably.
installing distributor/timing on sbc 350 075turbo Hotrodding Basics 38 05-19-2010 07:33 AM
Cam Timing PLEASE HELP!! maxpower_454 Engine 4 04-11-2009 07:02 AM
Cam Timing reflog Engine 13 07-08-2008 10:00 AM
cam advance/retard & dizzy timing wayneair Engine 5 12-14-2005 07:50 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
