You got it right. At 6-12 the rotor should be pointing at #6, at 12-12 the rotor should be pointing at #1. You can put it back together either way.
If you put it back with cam/crank in 6-12 position and rotor at #6, when you rotate 180 degrees it will be at 12-12 and rotor at #1. And vice-a-versa. If it is a new cam, you ought to degree it to confirm the valve timing. John |
Ok understood, now when I found TDC at 6-12 the #1 cylinder had the compressed air coming out the spark plug whole, when I turn it 180 degrees, and have it at 12-12 will I feel the same compressed air come out the #6 cylinder (since it happen with #1 at 6-12)
Yes.
As you rotate the engine the next cylinder to fire will be on its compression stroke. So, as you approach the 6-12 position the #1 piston is coming up in the cylinder, both intake and exhaust valves are closed, and the fuel/air mixture is being compressed so you will feel air being forced out of the spark plug hole. The firing order is 1-8-4-3-6-5-7-2 (on the GM engines I am familiar with) On one revolution of the cam sprocket, each of these pistons reach TDC, in turn, every 45 degrees of rotation. So at 45 degrees you would feel air being pushed out of the #8 spark plug hole, etc. -- at 180 degrees, the #6 sparkplug hole. And of course that is why it is important to have the spark plug wires going to the correct spark plug in the right order. John |
| Cam Correct Variable Cam Timing | upstand2 | Engine | 27 | 08-01-2009 09:47 AM |
| Roller Cam Install - Cam Button & Timing Cover Help | leejoy | Engine | 10 | 12-01-2007 04:28 PM |
| Help with timing Chain and timing cam install | LXZ590 | Engine | 7 | 12-08-2006 10:01 PM |
| cam timing? | runn141 | Engine | 9 | 11-24-2006 10:55 PM |
| another cam ouestion...ie...cam timing | VETTE GUY | Engine | 0 | 06-28-2003 11:29 AM |
