cam timing gear got into the block a little - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2005, 08:09 PM
74huggerorange's Avatar
I have a 70's 350 and the upper cam gear of the timing chain has gotten into the block a little, the raised section on the back of the gear wore into the block a little around the outside of the cambearing. It didnt hurt the bearing or anything it just wore down that protruding surface outside the cam bearing a little. Why did this happen? What is it going to take to fix this and prevent it from happening again? I will be installing a double roller cloyes street timing chain and gears. Thanks so much
Old 06-30-2005, 09:55 PM
black thumb learner
just a guess but I'd take that cam out and have a close look at the lobes. something wore out in there to let it slide back and forth. Prolly why you're in there redoing the timing chain too
Cam position in a big block Chevy JamesRS Engine 0 07-19-2004 03:25 PM
Valve timing: What's the purpose of degreeing a cam? killerformula Engine 9 06-09-2004 11:16 AM
cam timing off??? Pony Engine 2 05-08-2004 10:21 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
