cam upgrade - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2013, 08:51 AM
cam upgrade
I have a 83 z28 camaro with a chevy 350 with a 6 in high rise intake and a 650 holly carb everything else is stock. I want to a a beefier cam for a little more low end torque. Its all run through a 400r trans with 3.42 rear gear. What is the best camshaft and rollers i can use?
Old 03-03-2013, 08:58 AM
vinniekq2's Avatar
what are the present cam specs?for a torque upgrade you might also need an RPM increase depending on how much more torque you want.
What kind of exhaust do you have now?
What other future improvements are you considering?
Old 03-03-2013, 09:36 AM
ditch the tall intake and go back to a dual plane intake
Old 03-03-2013, 09:40 AM
i just have headers for now its a project car. i dont know what the specs are on the stock cam. its very mild between 1500 and 2500 rpm for a decent idle.
Old 03-03-2013, 09:49 AM
vinniekq2's Avatar
buy the cam when you need it
Old 03-03-2013, 10:11 AM
BigEd36's Avatar
According to the info I've seen 83 Z28's all came with 305 engines, so what is your stock 350 from originally? That will help us to determine the specs of what you're running now.
5.3 Cam upgrade jake_arcticcat Modern Electronic Engines 0 10-13-2012 12:38 AM
cam upgrade question ChadGresham Hotrodding Basics 5 05-26-2011 09:29 AM
roller cam upgrade dutch paul Engine 4 12-22-2010 10:10 AM
Chevy T.B.I. Cam upgrade MY88K5BLAZER Engine 4 06-15-2009 04:47 PM
vortec cam upgrade Sudden Psycho 31 Engine 2 05-03-2004 10:23 PM
