cam upgrade question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2011, 05:33 PM
Supporter of the 4.3 liter V6
Is it possible to take a stock 4.3liter Chevrolet motor and put a little more aggressive cam in it without changing anything else? i know i will have to tear apart the front end to install it but in interest of saving money i want to know if i have to change rockers and pushrods and all of those good things as well. any help is greatly appreciated.
Old 05-24-2011, 05:43 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
need more info
comp cams has a lot of cams
i would call the tech line and talk to them
Old 05-24-2011, 08:54 PM
ok i went on their page where you put in your truck info and they recommend a cam for your truck, hopefully i'll figure out what i need
Old 05-24-2011, 10:46 PM
techinspector1's Avatar
Wiki Edits: 326
Chad, if like you said, you are just looking for a little more umphh, choose the first cam in the grinder's catalog. Check through Crane, Isky, Crower, Lunati and Comp and look at their very first catalog offering for your motor. That'll be the cam that you can just swap out with the stocker, running it on stock valve springs. Something on the order of 194 intake/204 exhaust degrees duration @0.050" tappet lift will do the trick.
Old 05-26-2011, 08:33 AM
also does anyone know the stock specs of a camshaft in a 1986 4.3 liter Chevrolet motor?
Old 05-26-2011, 09:29 AM
Last journal entry: shelby
dont know the specs on stock cam, but engle also has great cams,and can make you one for what you want to do (if they have the v6 casting/billet/core)
Ford 9" disc brake upgrade question bebopwally Suspension - Brakes - Steering 3 07-04-2010 03:49 AM
column upgrade question Mad56 Suspension - Brakes - Steering 3 12-26-2009 02:30 PM
Stereo Upgrade Question. Eric63M Electrical 1 12-23-2009 01:01 AM
Camaro 10-bolt 8.2 upgrade - gear question EricTopless68 Camaro Transmission - Rearend 0 02-23-2004 09:10 PM
First time upgrade question SS Power Engine 1 07-12-2003 03:34 AM
