Cam/Valvespring Confusion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2008, 07:01 AM
As noted in another thread, I have a set of Summit brand aluminum heads and a Lunati Voodoo 60102 cam. I've been told that I will need to run shims regardless of spring height due to the nature of aluminum (valvesprings running directly on the aluminum is not good).
The confusion is about the spring pocket diameter. The spring pocket diameter is larger than the diameter of the recommended valvesprings from Lunati. There shouldn't be a substantial amount of clearance between the spring and spring pocket should there? I'm thinking that there should be a snug fit to prevent the spring from walking around inside the pocket.
Are there shims or spacers available to compensate for the differences in diameter? I've also been told that springs are available in the larger diameter. I just need to specify spring rate, height, etc. In other words: two springs with different diameters, but with the same specs. Is this correct? I'm sure the cam doesn't care what the spring diameter is, as long as it has X amount of pressure, etc.
Any help is appreciated.
Thanks,
300Deluxe
Old 01-10-2008, 11:36 AM
Last journal entry: PICTURE TEST
heads
I'll start off by saying that your looking for a spring locator, not a shim. People call them a few different names, like spring cups, or spring seats among others.
They make the spring locators in ID type and OD type.
The ID (or inside diameter) type locate off of the inside of the spring.
The OD (or outside diameter) type locate off of the outside of the spring.
You can use either one. you need to know the guide dameter at the base of the spring pocket, the inside diameter of the spring and the outside diameter of the spring. Call a cam company, not Summit or Jegs and give them the info and they will give you a part number.
If you can't get help PM me the sizes and i'll look them up for you.
Keith
Old 01-10-2008, 12:47 PM
Thanks for the suggestions guys. I'm gonna dig into it and see what I can find out.
Please help me pan out this confusion with SS Brake Lines! djjc76 Suspension - Brakes - Steering 20 12-15-2007 04:58 AM
2 speed fan confusion wayneair Electrical 5 05-13-2006 04:28 PM
Confusion about Alternator wiring diagram Bigg Redd Electrical 10 12-28-2003 12:25 AM
Vacuum Advance/ timing confusion! Zeder Engine 4 07-11-2003 03:25 AM
Wheel Confusion Bill Ford Suspension - Brakes - Steering 2 06-19-2003 06:22 PM
