Cam wear plates/thrust bearing
You probably dont need any of these items with a hydraulic cam,they dont move like a roller cam will.But Crane and Comp Cams both make high quality double roller timing chain sets that come with a thrust washer that goes between the upper timing gear and the block and this will prevent the timing gear from rubbing on the block.Might give you a little peace of mind!
Thrust washer
Thanks for the reply. The timing chain I have didn't come with a thrust washer but I saw in the Summit catalog they have 2 different sizes, would you have any idea which one would be correct for my block? |
Thrust Washer
I'm not quite sure what you mean by 2 different sizes,but if you have a 1965-91 Mark IV big block a good choice is Crane's Pro-Series roller timing set part # CRN-13984-1 which comes with the correct size thrust washer.Let me know if this is the info you want.
| flattened cam | 383vette | Engine | 7 | 05-04-2004 10:02 AM |
| The cam mistake is running, well, kinda! | Jmark | Engine | 12 | 12-31-2003 12:49 AM |
| BBC cam troubles | 2wld4u | Engine | 6 | 06-18-2003 02:21 PM |
| Cam Wear Tolerance? | 54 Chevy | Engine | 2 | 01-09-2003 12:30 PM |
| cam selection | chevyelc81 | Engine | 9 | 09-17-2002 06:41 AM |
