cam that will idle like no other but is no slouch on the low end, any suggestions? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-24-2005, 09:34 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Genie Genie in the lamp, can I have 3 wishes.........?????????
  #17 (permalink)
Old 12-24-2005, 09:49 PM
black66's Avatar
www.airriderz.com
Sound
I am not a engine guru. But here is what I am running and how it sounds. Not the biggest lope, but it will give you an idea of a streetable 350 that runs 11's
Comp Roller Cam 245 duration @50 .600 lift intake and exhaust.
3200 Stall bolted to a custom built 700R
4.56 rear gears
Old School Camel Humpers 2.02's with a little magic dust.
Torker II Intake
Mighty Demon 750
Intial timing at 20 degrees, with total of 36
Chevy Small Block 355 . Best run of 11.488 1/4 @ 120.08 mph .
And I run power brakes with no vacuum issues.
Sounds like this CLICK HERE My x pipe in the exhaust really smooths out the exhaust at idle and is much more lopey with x pipe removed.
I have engine components people on this forum said will never produce power, and would be a dog on the bottom end. My 1/4 mile time say other wise for a 4100 lb car and a small block.
Happy Holidays.......
  #18 (permalink)
Old 01-21-2006, 12:15 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
Build the engine properly with a smaller cam like a 204/214 or something like that. You can make it idle retardedly but playing with your carb and distributor.
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
sbc 400 low oil psi at idle camino_man Engine 7 08-01-2005 06:08 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 08:52 PM
I need a good cam and bottom end selection for a 350!! 2506CYL Engine 2 05-23-2003 04:28 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
