cam that will idle like no other but is no slouch on the low end, any suggestions? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2005, 12:30 AM
Warrant's Avatar
72 Nova, 65 Rambler, 37 Chevy
I want a cam that idles like crazy, but still has low end torque and has a 5500 or so RPM limit. My engines a chevy 350 and I plan to use a 2400-2600 stall converter with 3.73 cogs. Should I look for a cam with a shorter intake duration with a long exhuast? any suggestions? Thanks
Old 12-23-2005, 01:09 AM
I'd suggest you re-think your cam requirements. A cam that 'idles like crazy' isn't going to be responsive on the low end and isn't going to be very friendly with your converter. Something in the 220 @ .050" lift range will be pretty much all in by 5500, will work well with a 2400 stall converter and will have good off-idle response.
Old 12-23-2005, 03:53 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
You are talking opposites. Overlap will give you the crazy idle, but short duration (and the limited overlap associated with it) will give you low end torque.
If you're hell-bent on it, you'll have to do a completely custom cam. Here's what you need: You need mild duration. I agree with onovakind67; no more than 220 @ 50 duration on the intake. To get a slightly lumpy idle you could have a custom cam ground on a 107 LSA for use with roller lifters and a fast exhaust ramp, but you'll be giving up idle vacuum, power brakes, need to completely recurve the idle and primary fuel curves and the entire ignition curve.
Basically what you're asking is for the least possible street drivability, weak power, and losing the ability to run any vacuum-driven accessories like emissions equipment, EFI, power brakes, or A/C and climate control.
You'll end up with all the bad parts of a hot engine, but none of the heat... just to attain a lumpy idle.
Old 12-23-2005, 05:26 AM
FEDDO's Avatar
cam
For the cheap, go with a factory 350/350 hyd cam.
Old 12-23-2005, 09:26 PM
techinspector1's Avatar
Wiki Edits: 326
The only guys you'll impress will be the geeks. Racers and old guys will know better.
Old 12-23-2005, 10:33 PM
smallblocker2's Avatar
L79 327 5SPD S10 '65GTO
Get a cam with about 70-75 deg's of overlap, That's a lot for a driver, but you can make it torqey. Get one on a 106-108 LSA,with as much lift as possible, then get heads from a 305 or fuelie heads with the small valves, and chambers, get bigger exh valves if possible. A little bowl blend and short side radius work for velocity. keep compression up around 10.5, get a dual plane intake, with either a q-jet or an anular holley, and a free flowing exhaust. Any catylitic's or exh. manifolds will kill you.
She won't be a monster up top, but she'll have a lopey idle, and pull from 15-1800
An overdrive and steeper gears would help. should be able to get a 850rpm idle.
Also, If you don't mind adjusting the valves twice a year, get a solid cam. Hydraulics tend to bleed down at idle reducing the actual duration, and taking away that nice brap-bu-bu-brap-bu-bu
Later
Steve
Old 12-23-2005, 11:13 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Build an otherwise mild engine with low compression a gigantic cam then stick a big roots blower on top........ j/k
Old 12-24-2005, 09:26 AM
coldknock's Avatar
The best off the shelf cam for what you want is a Crane Energizer 274H06.
Pn. 10017
274 degrees total
218@0.050
0.450" lift
106 LSA
Make sure your compression is at least 9.5-1, and I don't mean the number on the piston box either, measure everything to be absolutely sure. If you don't, those 10-1flat-tops will probably have you at 8-1 and the engine will be an absolute dog.
Larry
Old 12-24-2005, 09:46 AM
edge's Avatar
Time is short, are you ready?
Everyone has their opinions, but I am going to make this statement based on personal experience, not a technical explanation.
If you have some decent heads, I think the Performer RPM cam will deliver what you want. It has a fairly lumpy idle, and in my engine had great throttle response and good mid-range. It pulls just as advertised (up to 6500). My setup was a 355, 9.5-1, Edelbrock RPM heads, 650 DP carb, HEI, 1 5/8 headers, 2 1/2" duals, 2800 stall, 4.10 gear with 28" tall tires. I did not need a vacuum cannister for the brakes to work, but I did add a cheap Summit can for safety.
What heads are you running?
Ed www.edgesz28.com
Old 12-24-2005, 09:57 AM
NAIRB's Avatar
Pn. 10017
274 degrees total
218@0.050
0.450" lift
106 LSA
Larry
I concur here. This is the Crane's "3/4 Cam" and is designed specifically to give that rumpety sound and still maintain a level of driveability.
Old 12-24-2005, 02:25 PM
I concur aswell. That cam will give about 62deg's overlap, which will work well with their 9.5 compression recommendation
Old 12-24-2005, 04:20 PM
Warrant's Avatar
unfortantly, im stuck with 882 heads untill i can get better heads, this probaly changes things huh, choking off the cam, but will it still work for now?
Old 12-24-2005, 05:08 PM
Wiki Edits: 31
yes, but it is gonna be a real dog.
Old 12-24-2005, 05:28 PM
just get a junkyard set of non-swirl port 305 heads. that'll get you by
Old 12-24-2005, 05:46 PM
coldknock's Avatar
305 heads with 58cc chambers will bump the compression ratio close to 10-1. The downside is further reduced flow with smaller valves and ports. It would be a waste of money.
Larry
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
sbc 400 low oil psi at idle camino_man Engine 7 08-01-2005 06:08 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 08:52 PM
I need a good cam and bottom end selection for a 350!! 2506CYL Engine 2 05-23-2003 04:28 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
