camaro clip - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2012, 09:36 PM
camaro clip
ok i got a camaro clip on my shoebox heres my question i know the upper arm can be sucked in by using alingment shimes. the top of the tire is fine can i use a shorter lower a-arm to bring the bottom of the tire in.
thanks for any help not to knowledgable with front ends
Old 01-23-2012, 02:13 PM
1971BB427's Avatar
What are you trying to accomplish? Have you run out on top, so you want to bring the bottom in to allow it to be aligned? They do make adjustable tubular A arms for both upper and lowers, but if you need more adjustment on top they also make offset shafts for the upper arm, so you can get things lined up easier. They're only about $80 a pair, where adjustable arms are around $500.
Old 01-23-2012, 02:22 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
fatmans sells 1 inch shorter arms. you also need to cut the spring because it gets longer as it moves inboard. i take it your are too wide ?
Old 01-23-2012, 02:23 PM
shine's Avatar
SPI Thug
ps..... you cant screw with geometry .
Old 01-23-2012, 03:50 PM
poncho62's Avatar
Wiki Edits: 5
Different offset wheels might do the same thing
These are the types of things that happen when the measuring tape is not used in pre planning
Camaro Clip PEE DEE Suspension - Brakes - Steering 3 07-05-2011 09:48 AM
need help with camaro clip for '48 pontiac jdube Suspension - Brakes - Steering 4 01-31-2011 03:50 PM
camaro clip install M-100 80ta General Rodding Tech 9 01-10-2011 10:19 PM
camaro clip 1980 toms3300 Suspension - Brakes - Steering 2 11-23-2009 03:22 PM
Clip the front of a 59 Chevy pu with a 70 Camaro Front clip? Will it work? classicappraiser General Rodding Tech 6 10-16-2006 12:05 PM
