Camaro clip into '40 Plymouth? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2009, 08:22 PM
hi guys, looking for a little advice on the '40 Plymouth Coupe I just bought. I have the original frame and I also got with it a '79 Camaro front subframe. I'd like to use the camaro clip for better build cost, suspension, steering, brakes, etc. (my wife wants to drive it too). Has anyone here ever attempted a similar project?
the plot thickens though... the engine I have is a 351W ford block, does anyone know if that will fit between the camaro rails?
Old 08-05-2009, 05:55 AM
Will I ever get it done?
Last journal entry: Hood
When I bought my 41 Chevy, it had a late 2nd gen sub-frame in it. It was so wide, you couldn't turn the car unless is was jacked up really high in the front. The tires would hit the fenders. I got another frame and put a MII in it. Check the hub to hub width on both front ends and you will probably find 4 - 6 inches difference.
The problem you will have with the 351 isn't the width. If you have problems, it will be with the oil pan. Blue oval guys on here can probably give you the part numbers you need for a rear sump conversion. I have a ton of clearance between the pan and crossmember on my 350 in the MII. Not sure if it would clear a front sump though.
Old 08-09-2009, 11:14 AM
72 grabber 51F-1 65 chevystang
You could get a rear sump pan at any junkyard. I would measure the track width before I did any cutting
Old 08-09-2009, 12:24 PM
life is a temporary assignment
I have done a lot of Camaro clip's in many different car's in truck's,But I have to agree with old fords on this..
Old 08-10-2009, 08:27 PM
thanks guys. I believe the Camaro track width will be slightly wider, but we are planning on widening both the front and rear fenders for the camaro clip and wider tires in the back. As long as I've done my math right I think I've figured out it will be fine. Again thanks for your insight.
40 Plymouth front end John W. Martin Suspension - Brakes - Steering 7 10-28-2003 10:38 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
40 plymouth HELP!!! dave5113 Suspension - Brakes - Steering 5 02-13-2002 08:55 AM
1948 Plymouth front clip rem3535 Suspension - Brakes - Steering 1 02-10-2002 05:54 PM
