camaro coil spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2010, 03:25 PM
camaro coil spring
Hello all
Is there a differece in coil springweight ratings beteen a 6 cyl camaro or a v8 z28 from 72 t0 78 years .? If so how can you tell ? I need to replace them in a pick up I subframed . Thanks Larry
Old 08-25-2010, 03:36 PM
ericnova72's Avatar
More for Less Racer
Don't know how you would tell without a spring rate tester, or having both side by side to measure wire diameter differences or number of coils or free length differences, but they are definately different. Six cylinder spring will be around 260lbs/inch rate, Z28 spring in the 330-350 lbs/inch rate.
Old 08-25-2010, 06:51 PM
camro spring weight
eric
Ok , do you mean compresion of spring equals 226 pound s per inch that is compressed? Thanks Larry
Old 08-25-2010, 08:27 PM
ericnova72's Avatar
More for Less Racer
Originally Posted by old trucke
eric
That is correct, rate per inch compressed.
Old 08-26-2010, 10:03 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I believe there is also a different spring rate within the V-8 arena, i.e. small block to big block GM. When I "resprung" my '68 Nova I bought what were advertised as big block springs.
Semper Fi
72 Gran torino need stiffer front coil spring Ratoflic Suspension - Brakes - Steering 1 10-07-2009 05:49 PM
Front Coil spring orientation on IFS fosterdl Suspension - Brakes - Steering 2 05-16-2007 06:51 PM
1970-1973 Camaro Spring HELP! mark48183 Suspension - Brakes - Steering 2 12-16-2006 08:22 PM
need to know coil spring rate runn141 Suspension - Brakes - Steering 2 11-27-2006 04:00 PM
coil spring install on camaro subframe kid Suspension - Brakes - Steering 3 08-25-2003 07:26 PM
