Camaro compression test....burnt valves??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2004, 12:07 PM
Rubberman2003's Avatar
I just did a compression test on my camaro, a some of the cylinders read around 150 or so, a few read 95-100. Those low ones could have burnt valves, correct? if so im gonna pull a head off and look. the motor has all new internals ect ect, 1000miles on motor, but it did run low on oil once (long story) wasnt my fault though.
Old 02-08-2004, 12:21 PM
camaroman7d's Avatar
Here is a quick and easy way to figure out if it is a bent/burned valve or rings. Add a little oil to the low cylinder and retest them, if the numbers come up then it is the rings, if the numbers are still low it is a valve problem. Try this before you pull the heads, if it turns out to be the rings then you have no reason to pull the heads, until you are going to rebuild the engine.
Hope that helps, good luck
Royce
Old 02-08-2004, 12:42 PM
ok gonna try it now
Im gonna goto town and get a new dist cap. One of the prongs is a diffrent color (really dull) maybe thats it.
Old 02-08-2004, 02:02 PM
GSXMEN's Avatar
Have you been having this problem since fired up?
I'll be curious to see how your new comp. test turns out.
Old 02-08-2004, 05:15 PM
I am to LOL i did a few of the Cylinders, i have to do some from underneath, gonna do it tues. a few of them were a little low, gonna try to oil trick to them tues. Gonna get a leakdown tester monday.
