Camaro Doesn't like to start - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2002, 10:08 AM
Post Camaro Doesn't like to start
I recently purchased a camro from a buddy of mine for only 900 bucks. its a pretty good car all in all but it doesnt like to start all the time. If its really hot out it tends not to start, and the enegine gets very hot if you run it for long periods of time. One day when it was about 100 degrees out it would start at all for about 4 hours. this is my first car and im new to all this, i dont really have much of an idea as to what is causing this. <img src="confused.gif" border="0">
[ September 08, 2002: Message edited by: loserpunk86 ]</p>
Old 09-08-2002, 11:41 AM
Post
damn spelled camaro wrongs....well there.i corrected myself
Old 09-08-2002, 12:52 PM
Last journal entry: Doors
Post
What year car is it? Carborater? and milige of it??
Old 09-08-2002, 02:06 PM
Post
its a 3rd generation camaro,and its fuel injected. Im not sure of the exact milage. it does leak oil and transmission fluid, it may have some blown seals or gaskets. i havent had it long enough to really look yet.i dont know if that could have anything to do with it.
Old 09-08-2002, 02:35 PM
Post
oh by the way the engine is a V6.
Old 09-08-2002, 05:20 PM
MonteCrl's Avatar
Post
many times when GM starter solenoids get hot they don't like to crank. Just an idea.
Old 09-08-2002, 08:35 PM
slider in wa's Avatar
Slider in Wa.
Post
Make sure you battery cables are supper clean and bright. At both ends, At the battrery and where they hook to the starter as well as where the neg hooks to the frame. Receintly i had a constant clicking nose. the truck was hard to start, and would grind down the battery . I traced it to a loose groung strap at the engine, no more clicking no more hard starts.In addition make sure you groung the engine to the frame as well.
Old 09-09-2002, 03:36 PM
bullheimer's Avatar
NEVER use credit cards!
Post
happens to chevies all the stinkin time bro. need to sheild it from the hot exhaust. after a while they get tempermental and you should replace it first which is what you should do. then reinstall with a heat sheild. metal or even a piece of asbestos secured in there somehow. trust me on this one
Old 09-09-2002, 04:55 PM
Post
thanks for the information
