Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Camaro Door Straighten
  #25 (permalink)
Old 12-14-2012, 04:42 PM
mdrodder58 mdrodder58 is offline
right begind the dent
you can drill a hole behind the dent careful not to go tru the outher panel just the beam and use that to get to the areas you need to push out but it will allso lossen the bond that was used between the beam and the panel so it you dont want a rattle you should use a good body caulk use a auto caluk not one for home
