Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Camaro Door Straighten
  #26 (permalink)
Old 12-14-2012, 07:17 PM
timothale timothale is online now
Wiki Edits: 27
Hay hook time .
In the factory a lot of the metal finshers had their own special tools they made. Most had some J or L hooks, usually 12 to 18 inches long, made from trunk lid or hood torsion springs. The ends were sometimes pointed or with a ball end. they were used in areas where you couldn't get a hammer, On cowl tops they would punch a hole in the upper firewall, insert the end of the hook then using leverage work the ding up , sometimes by twisting the T handle . On minor dings on doors behind the guard rail. The holes in exposed areas were filled with a pinch of body sealer and thumbed kind of smooth.
