Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Camaro Door Straighten
  #30 (permalink)
Old 12-22-2012, 12:09 AM
MARTINSR MARTINSR is offline
Originally Posted by tech69 View Post
thing that sucks about the hole era is a lot of guys just used the screw slide hammers and made teepees out of the hole and stretching the metal in those areas and thinning it. Instead of rolling the metal out they just yanked hard and if you don't roll it out right you get teepees. If you know what you're doing the teepee effect won't be an issue.
I was a master slide hammer dent puller. or should that be
One of the worse things we did was drill the holes, the teepee or as we called them volcanos were a sure thing with a drilled hole. But if it is punched with an awl the volcano is going IN so when you pull it out you end up with something much flatter.
I can't believe that I just did a "Basics" on a slide hammer dent puller.
