Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Camaro Door Straighten
  #35 (permalink)
Old 12-28-2012, 06:43 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
Your on the right track...I was stripping the whole car anyways got the nose done and the door when I decided to scrap the door it takes less that an hour to strip a door but thats the easy part I'm rebuilding the door with new seals window regs& motors,rebuilt hinges etc...
Yours is a whole different type of job,I understand this..taking the door off will open a big can of worms and get expensive so you just want to fix the damage and only the damage...two completely different jobs...
That said, I dont just go wandering around the yards looking for a part ,I get online find the part and how many there are so I can pick and choose..Once I found the best door it took less than 15 min to pull it ,its a complete door so if I wanted too I could just replace it as a unit and just change out the lock cylinder Once I left the shop I was back within two hrs and had lunch too.
so far I have two hrs getting it ...100.00
the door itself.............................50.00
1 1/2 hrs stripping the outside and rebuilding the hinges...75.00
today I'll spend a few min and spray the epoxy primer on the outer shell and tomorrow 1 1/2 hr fixing 1/2 a dozen dime size dings but lets call it another 4hrs or 200.00 altogether thats 425 for a freash door ready to paintmost of that is all preppeing that I'd have to do anywayactual body work is only 1 1/2 hrsSo in my case its the way to go being my labor is expensiveIf your not counting labor its ok to spend two days doing body work only its just 10-30.00 for a can of bondo.
But to tell the truth ,if I was doing that job I would'nt bother welding up the holes,I'd just stuff it too...Theres the right way for every job and thats the right way for that particular job...mostly I was just showing there are good doors out thereand they are prtty cheap I found two less than 5 mile away ....and dont buy stuff from Ebay and amitures get your parts from yards that know how to grade the quality of the part so you donet waste time and money buying junk....Location DOES have a lot to do with the selection and quality of parts.... a good salvage yard will ship all over the country....
The Following User Says Thank You to deadbodyman For This Useful Post:
cyclopsblown34 (01-03-2013)
